-29%
PC portable Gamer ERAZER DEPUTY P60 – 15,6” FHD 144Hz – i7-12è ...
999.99 € 1399.99 €
loss problems Escatop
loss problems Escatop Empty loss problems Escatop
Message  zacca Jeu 26 Mar 2015 - 14:04
Good Morning,
I had read that someone had had problems with loss Escatop filter compartment, but I can not find the solution.
I happen to have settled in Italy even more 'times by the same customer loss nell'escatop, but after a short time maybe 2/3 years the problem reoccurs, and the customer and' discontent.
Someone and 'managed to solve the problem of aperdita bulkhead with some sealant particular?
accept advice not to have more x 'problems.
thank you
zacca
Nombre de messages : 4
loss problems Escatop Empty Re: loss problems Escatop
Message  Paulo-17 Jeu 26 Mar 2015 - 14:54
loss problems Escatop 1301310943382112410819787
You should contact the Wat customer service because they are studying a two-component adhesive that should solve the problem.
It should of course replace the plate which is between the filter and the engine to ensure a good seal.
loss problems Escatop 091026114230211244722717
loss problems Escatop 100811093406211246548709
Message  zacca Jeu 26 Mar 2015 - 17:42
x If you know the name of this bicomponenete?
thank you
zacca
Message  Paulo-17 Jeu 26 Mar 2015 - 18:10
No, for the moment the product does not appear to have been used yet, no second-hand return.
